How to Establish Board Connection Using SSH
You can use any standard SSH client.
The following instructions are for the PuTTY SSH Client.
If you do not have PuTTY, download it from official website.
Instructions
  1. Download SSH key file
  • ssh_port = ssh_port
  • serv_port = serv_port
  • user = user
  • rem_ip = rem_ip
Link to SSH key file, ssh_port, serv_port, user and rem_ip are shown on the Connection and Tools page.
  1. Run PuTTYgen.
  2. Select “Conversions→Import key” 1. command on the PuTTYgen menu and select the downloaded file as the key.
    3
  3. Save the generated private key.
Do NOT click on the “Generate” button.
4
  1. Run PuTTY.
  2. On the configuration tree, select “Session” branch. Specify host name in the corresponding field using the user@rem_ip format. Specify ssh_port in the “Port” field. Make sure the “Connection type” radio-button is at "SSH".
    6
  3. On the configuration tree, select “Connection”“SSH”“Auth” branch. Specify the file path for the generated private key generated in step 4 in the “Private key file for authentification” field.
    7
  4. Click “Open”.
