Port forwarding
If you do not have PuTTY, download it from official website.
Tutorial video
Instructions
- Download SSH key file
- ssh_port = ssh_port
- serv_port = serv_port
- user = user
- rem_ip = rem_ip
Link to SSH key file, ssh_port, serv_port, user and rem_ip are shown on the Connection and Tools page.
Run PuTTYgen.
Select “Conversions→Import key” 1. command on the PuTTYgen menu and select the downloaded file as the key.
Save the generated private key.
Do NOT click on the “Generate” button.
Run PuTTY.
On the configuration tree, select “Session” branch. Specify host name in the corresponding field using the user@rem_ip format. Specify ssh_port in the “Port” field. Make sure the “Connection type” radio-button is at "SSH".
On the configuration tree, select “Connection” → “SSH” → “Auth” branch. Specify file path for the generated private key in the “Private key file for authentification” field.
On the configuration tree, select “Connection” → “SSH” → “Tunnels” branch. Specify serv_port in the “Source port” field. 1. Specify destination in the corresponding field following the 127.0.0.1:serv_port format. Click “Add”.
Click “Open”.
Do NOT close the black window until debugging is over.
While using port forwarding, use localhost as the IP-address and serv_port as Port.
